kpmengr
Everything posted by kpmengr
  1. kpmengr
    Chain Slider
    Found one. Thanks Factory.
  2. kpmengr
    Chain Slider
    Bump. If you got one shot me a PM
  3. kpmengr
    Chain Slider
    Sprinlr- do you have a pic? Factory- I sent you a PM.
  4. kpmengr
    Chain Slider
    Looking for a black or grey aftermarket chain slider for front of swingarm. My zip is 93455.
  5. ebay a set of blaster rear hubs. They are 4-100 and slide right on the banshee axle spline
  6. Heading south to Orange County, CA on Tues. Call me 805-268-7756 Kevin
  7. HONDA EU1000i Generator / Inverter - Quiet & portable gas powered unit - Top model out there. Perfect for camper or boat. Runs like new. Located in Santa Maria, CA but have family in Westminster, CA and could deliver. $550
  8. Got the shift pro. Looks good, thanks!
  9. payment sent on shift pro
  10. Is this a full drag port, dune, MX?
  11. All done. I had to take the brake disk off and hit the carrier both sides until it came off. When it let loose, the bearing on the brake side stayed on the axle. I had to cut that bearing off. Took awhile but happy with the results. Thanks again for the help.
  12. Thanks guys. It sounds like it does not take as much effort to get it off as I was thinking. I will try the dropping-it-on-4x4 idea tonight.
  13. Got my spiffy new durablue axle waiting to be installed. Going to re-use the brake and sprocket hubs. Did a search and it seems most remove the axle and carrier from the swingarm and tip the hole shebang on end before applying "force". Sprocket hub slides off easy. My question is: What do I whale on to get the carrier off? My search came up with a lot of vague help like: "just let loose a fury like the world has never seen". Hehe I liked that one! But, the brake disk and hub are in the way. Do I need to remove the brake disk from the hub? Even if I did, the only place to hit is on the carrier mount flange. Carrier is not worth much, I know but I am trying not to destroy it if I dont have to. What am I missing?
  14. I need rear exhaust hangers for toomey pipes
  15. Price lowered to $50
  16. Price lowered to $25
  17. No worries with this radiator. Make me an offer.
  18. Just taking up room. Make me an offer!
