nate_4027
nate_4027's Achievements
  1. Come on somebody's got to know the answer. Help me out guys.
  2. My upper a arm bushings took a crap. They are needle bearing. I was wondering that since I have aftermarket arms will stock busings work or do I have to buy them from the company that makes the a arms themselves?
  3. How do those upper a arm busings come out?
  4. Come on guys I really need some help here. Thanks
  5. I have checked all of those things and the play is definately coming from the upper a arm bushings on both sides. Can these be replaced? If so how do I get them out and can i use stock bushings or do they need to be aftermarket to go along with my aftermarket a arms?
  6. I just recently purchased a 1998 model with widened a arms and rear axle. My problem is that when I get up into the higher speeds the front will start to shimmy. It appears that the play is coming from the upper a arm bushings on both sides where they bolt to the frame. I took them out and re greased everything and still had the same results but not quite as bad but still bad enough to where it needs to be fixed. The a arms do not have grease zerts. Any ideas would be appreciated, Thanks.
