I did a complete overhaul of my '98 banshee and am having trouble getting it to kick start. i can pull-start it and it will fire right up moments after dumping the clutch. I can kick it over all day and it wont start. Once i pull start it it will run forever...as long as i dont let it idle. as soon as i come to a stop and try to let it idle, it stalls. With these symptoms, im tempted to think its carb problems, since those are the only things i didnt work over. i'd love some input before i tear all the plastic off again and pull the carbs for a rebuild. everything was running fine before the rebuild until a crank main spit out the rollers. i put in a new crank, all new tranny bearings, seals, yamabond on the casing halves, clutch, flywheel/stator, degree key (yes it's installed correctly, double and triple checked) .040 over pistons, and 18cc domes in my cool head. Im running 91 octane with octane booster and 32:1 oil mixture with Lucas 2Stroke SemiSynthetic mix oil. I built the motor to run race fuel, but my local vp dealer charges 6.75 a gallon so i went with the 91 and additive. I dont think this is a problem since it runs great when pull started.
