Everything posted by [email protected]
  1. it has about 20 hours on rebuild.....compression is 110
  2. plugs are not new, however they are not fouled either....they are getting plenty of spark......I will be buying a case of plugs this weekend anyway though. Carbs are stock. I dont know what the TORS is? Parking brake is connected however we did make sure that it wasnt the problem.
  3. I will double check again this weekend but when the carbs were cleaned we counted the amount of turns for each side.
  4. my banshee does not want to run, the right side is spiting and sputtering and the bike wont idle. If I give it half choke it helps a little but its still not right. everyone tells me its the reeds but I swapped the right with the left to check it and its still doing the same thing. I have taken the carb apart and cleaned it out. I took the petcock apart and cleaned it to make sure I was getting fuel..........and yes the hose between the carbs is hooked up. not sure what else to do from here. If anyone has any suggestions please let me know......I am at a loss for ideas.
