only2stroke
Everything posted by only2stroke
  1. FOR SALE 2003 yamaha Banshee 350cc limited edition the two tone black and yellow, this ATV setup for MX and dunes, on it A-Arms +3+1 (from SO CAL FAB) with fully adjustable TCS shocks with by pass, +4 DURABLUE axle , ported cylinder (from Patriot Racing),carbs are 28mm Keihin PWKs, K&N filters, Wiseco Piston, Pro-Design CoolHeads with custom cut domes from Patriot Racing(for pump gas), Toomey Racing Pipes (T5), Toomey Racing Radiator, V-Force reed cages with the Pro Design V-Force compatible intakes, crankshaft trued and welded to prevent crank phase slippage and spreading due to increased power, adjustable timing plate set at +4 degrees (this plate can advance and retard up to 10 degrees), Carbon Fiber BeadLock Racing Wheels (10 x 5 Front, 4 + 1 offset, Single Beadlock) (10 x 10 Rear, 5 + 5 offset, Dual Beadlock), Paddles from Skat-Trak (Mohawks on the front wheels) (Extreme on the back wheels), TAG handle bar, nerf bars, non o-ring chain. I bought it from the dealer brand new, and I spent over 7000$ on this quad and used it less than 10 times, I
