Bernimx
    Yamaha banshee 2003, black/yellow, t-6.
Bernimx's Achievements
  1. It fires now ! All I did was re-tighten the connections, although none seemed to be loose... it worked so thats the essential. thanks guys
  2. I took all my plastics off and I took a look at my connections, they all seems fine... I don't want to have to bring the shee to the garage just for that
  3. Hi, I just put my t-6 on and went riding. 10 minutes later, the banshee starts to bog like it was seizing or lacking gaz. I immediatly turned it off, thinking it was seizing because it was lean. But today, I just realized it doesnt fire. What could have happened ? What should I check ? I need quick help because a guy is coming to try it this afternoon. THank you very much
  4. Theres no more idle problem. Just : why is there prestone lightly coming out from my cylinder head nuts ? When i arrive from a ride a chek that and theres some green liquid on the nuts. please quick help
  5. Every nuts on cylinder head was slack, I had to retorque them all to 20 pounds. My gasket also seem to be leaking. It is brand new. help!
  6. I settled a problem : I had only cheked the rear prestone tank and it was full but I forgot to chek the rad themselves. So I added prestone and the heating problem is gone. But now I can see some oil come out from a few nuts of the cylinder head. What's going on ? Bad torque or is it the gasket?
  7. Oops I forgot to mention I had t-6 and their air filter and some little patched holes in the air-box.. I'll go bleed my rad, I didn't do it..
  8. Hi, first I wanna say I will really appreciate quick replys!! I just got my motor rebuild. .50 piston now. Bike : Banshee 2003 Main jet : 270 Pilot jet : 25(stock) Needle : new from toomey, supposed to be on the 4th notch. Pilot screw : 1
  9. Is AMSOIL good for premix 100:1 ? (what's written on the front of the can in big numbers) thank you for quick reply
  10. Hi guys, I just bough a 2003 Banshee with t-6, and I was wondering if it was OK to run yamalube in my tranny and yamalube for my mix also. Thank you
