machz05
Everything posted by machz05
  1. I am looking for one stock complete headlight for my banshee. I would possibly buy the pair if available. Please email me at [email protected]
  2. Thanks guys for the input, I wish I would have replaced them when I had it apart a year ago.
  3. It is quite a bit of smoke and it smells funky. I removed my cool head and tried the stock one and it did the same thing so it isn't coolant. As much as I don't want to admit it I'm thinking it is the crank seal. What a project!!
  4. Which crank seal is it or is there only one? I had to replace a shift fork about a year ago so the entire engine was apart. Do I have to split the cases again or is there another way?
  5. I am running Klotz oil at 40:1 mix. I have Uni filter two -one airfilter on it and I guess I could check the reed boots but wouldn't that make me run lean?
  6. I have a 1998 Banshee with Toomey pipes, Cool Head, and Vito's Power Pistons that were just put in. It has stock bore and stock porting on the cylinders. Out of no where one day I started it up and it started smoking really bad out of one cylinder (right). I ran a compression test and both seem fine at 145 (right) and 142 (left). I took both carbs apart and cleaned them, unhooked my T.O.R.S, and checked my reed valves and still it smokes. I noticed my transmission oil to be a little low and I was wondering if I could have an internal leak to where I am burning that oil? The left plug has a nice brown color but the right is black. Anyone have any suggestions!!
  7. Thanks but I bought a set from chapmanmd!! Really a great guy to work with. Nick
  8. I am looking for either the right cylinder or worst case a complete set of stock bore, stock ported cylinders. I do not want to have to bore them and don't need anything ported at this time.
