NMSHEE
Everything posted by NMSHEE
  1. I was wondering if you guys might be able to tell me what my hp might be? Its a banshee bored .040 over with wiesco pro lites, cool head 18 cc domes. stage 2 porting It has boyesen reeds. 3/8 reed spacers. It has keihin flat side pwk 34 mm carbs open k and n filters. with a boost bottle. Toomey t5 pipes. It runs off of race gas. Thanks
  2. I need evrything what are you asking for it all? Pics would be great send to [email protected]
  3. Im not sure what the cold compression is i will check it when i get it back together. Thanks
  4. Im looking for a banshee tranny Does anyone have one?
  5. I was wondering what fuel should i run in my banshee with 18cc domes,bored .040 over with some porting. At 5500 feet elevation? Thanks
  6. I think the gear im talking about is 5th, its #4 in the clymer book
  7. Ok sounds good thanks for helping
  8. Ok on the smaller shaft, the gear right after the smallest gear towards the little bearing, should that gear spin?
  9. I think i found the problem. One of the rotating gears is locked up on the shaft. I think it should rotate.
  10. Ok i tore it all apart and i cant find anything wrong. The forks seem ok and the drum is moving ok. 5th gear is the only free gear, the others are all bound up. And it hard to shift. Could it all be in the drum and forks, or do you think its the shafts? Thanks for your help
  11. My tranny has some weird problems, it only has 5th gear, 1-4 are bound up, you can shift in to these gears and it locks up. And there is no nutral. 6th gear is also locked up. Any ideas on whats wrong? Thanks
