BnShEsP986
Everything posted by BnShEsP986
  1. whne you get the head milled do they mill out the domes or is it somnething else?
  2. got nerfs and teather already
  3. thats what the rear looks like and what kind of swingarm do you reccomend like function and cost wise also would new sprockets help out for holeshots and pulling out of corners.o and i forgot to add i already have nerfs and a teather kill switch
  4. I have a 1998 banshee it has gnarly pipes with powercore 2 mufflers,wiseco pistons im not sure what compression ratio,uni filter airfilter thats does not use an airbox,jetting,for the tires its has holeshot xcr front and powersports bandits in the rear and i was wondering what is there that i can do except for the front suspension because im ordering an alba pro comp suspension kit with elkas and so is there anything i can do to set it up better and my budget is kinda tight and i will mainly be racing at Southwick,MA and the ground is loose sandy type dirt
  5. Also the track i will be mainly racing at is Southwick,MA wich has loose sandy type dirt
  6. I have a 1998 banshee it has gnarly pipes with powercore 2 mufflers,wiseco pistons im not sure what compression ratio,uni filter airfilter thats does not use an airbox,jetting,for the tires its has holeshot xcr front and powersports bandits in the rear and i was wondering what is there that i can do except for the front suspension because im ordering an alba pro comp suspension kit with elkas and so is there anything i can do to set it up better and my budget is kinda tight
