planetmoto
Everything posted by planetmoto
  1. look at my ebay auction complete esr kit want the chettah 500 from trinity
  2. did you have it on the cheetah or cub cylinders. the prox from esr has the cr 250 intakes. not that im doubting you just want to make sure
  3. will the 2 into 1 intake work on the 409 prox cylinder have the tmx 36mm and the space for the filters is very tight
  4. hey guys, need some help. just installed my esr 409cc cylinder. with the 4mm crank. it came with mikuni tmx 36mm carbs and his pipes , which look like shearer copies. a timing advance plate and 2 k & n filters. with 2 velocity tubes to mount the filters to the carbs. take into consideration that this is a pro x cylinder and the reed intakes are of the cr 250 design. a six bolt pattern. everything bolted on perfect. the problem beingis i cant mount the filters onto the carbs because the pipes are in the way. i have to apply pressue to the carbs and force them inward to put the filters on. if i had out of frame pipes it would be perfect. went from a trinity 2 into 1 setup and this is frustrating. any HELP different carbs etc.. thanks
