will a shit stator cause it to have spark sometimes and no spark sometimes, like on and off? if so, are they hard to install a new one?.. and do they go bad on older quads often? Will i need a flywheel puller?
i replaced the ignition coil first because thats what was wrong with it at first. I tested the switch on the trottle and its fine.. also my key and run switch are all good 2. How do i check the pick up on the magneto?
i unplugged the tors control unit and it ran for maybe 5 minutes and then died.. Now it has no spark. Its someting to do with the whole throttle electrical system.
ok ive recently started 2 rebuild my 87 and im having problems with spark.. It has some thing 2 do with the whole T.O.R.S. system. Is there any way that i can eliminate the T.O.R.S. and just have throttle cables running into the carbs? please help.... Also i had it running for a little while but when it runs it carbon fouls the plugs really quick. I think the top ends are shot since they havent been rebuilt once since it was brand new! Is this my problem? .. Help please
