RaceDave
RaceDave's Achievements
  1. Hello, I'm new to this site and I love it already! I have learned a lot so far from reading everyone's posts. Thanks I have a 2001 Bashee with the following: 18cc Pro Cool Head Cylinder Porting by Rudy Kurtz mid-2-top power porting V-Force 3 Reeds Ricky Stator 200watt stator & Advance Plate Ricky Stator Flywheel Toomey T-5 Pipes Vertex pistons, rings, pins, pin bearings-stock bore (the cyl.'s are perfect) I will be running 110 octane fuel ( a friend runs the above but with stock carbs) I plan to install the above parts in about 3 weeks when my cylinders return Here is my Question? Which carbs should I run? I have been told to run the Keihin 34mm PJ's from team alba. And to run their intake's & intake boots. But I am also hearing that I should run 30's, 33's or even the stock carbs? I'll pulling my hair out trying to pick a set of carbs out I ride Pismo, and some Dirt Trail Riding. Also which are better Keihin's or Mikuni's? Which are easier to tune? Any shops you suggest to buy from? Thanks for any help you can offer! Dave
