skunker
skunker's Achievements
  1. if still have the 02 frame ill buy it now!!!
  2. i already try that too and samething
  3. i already try to put friend's carbs on my banshee and same thing he wont idle except if choke is "on"
  4. can you explain to me why the 2 carbs and the reed valve are working on my friend's banshee but not on mine? we have the same set-up. the only difference being that the compression is 160lbs on mine and 150lbs on his. thx alot for those who try to help me
  5. bowls and jetting are ok because the carbs run ok on my banshee friends (we have the same setup)
  6. everything was ok until i clean the carbs i dont change anything just remove clean and replace the carbs
  7. i think my carbs are ok because i try those on banshee friends and they work so good
  8. i need a frame email me at [email protected] thx
  9. how much for the frame?? e-mail me at [email protected] thx
  10. how much for the 2 cylinder + shipping
  11. nope my carbs slide are ok
  12. but why everything run good before i clean the carbs??
  13. hi guys my shee wont idle except if the choke is "on" an he run like he is suppose, when y push the choke off he just want idle i check everythink reed and carbs run well on my friend shee so i guess those think are not my problem any one have an idea??? he run so well i just take off the carbs to clean an after this everything is f**k up 2002 shee V-force 2 ported an planed (21cc) stock carbs (whit those shitty TORS) pilot jet: 32.5 main jet : 300
