Black Ice
Everything posted by Black Ice
  1. already done it, it is somethin in the transmission b/c it doesnt do it when the bike is started
  2. ok, if i put my bike in neutral and roll it, it will roll for about 40 ft and then it will catch and act like it is in gear, but if u keep tryin to roll it it will let go and roll a little farther, does anyone know what is catching? any help would be greatly appreciated
  3. make sure u didnt loose ur little clutch ball that goes in behind the pushrod, i had that problem and it was a big pain in the ass
  4. heres a good one, which will win in a drag? the banshee or the quadzilla
  5. oh for sure man, i did all that, trust me, after i seen some of the worth this boy before me did, i took the time to double check everything else
  6. And yes one carb does leak a little gas out of the overflow tube
  7. i only replaced the right side b/c the person before me only replaced the left side about 2 months ago and that piston was in good condition, dont ask me why he only did one side to start with
  8. what would i be checking for and whats the easiest way to do this?
  9. i jus got done replacing the right side pistion and rings and the right and left side oil seals, both cylinders smoke a little, but the left one smokes more than the right one, the right side does not have any exhasut packing and the left does, will that cause this?
  10. yeah, i use the clutch to shift, and my bike is a 90 model, maybe my shift parts are wore, thanks for the info
  11. ok, when i take off hard (Drag Racing) it shifts into 2nd nice, but it seems like i have to kinda let off the throttle to hit 3rd, most of the time i shift,but it jus stays in 2nd, is this normal or what can be the problem?
  12. iight, cuz im tryin to save as much work as possible, spliting the cases is enough
  13. I was wondering if you have to take out the Clutch Release Lever to split the case to replace the right and left hand oil seals
  14. i was jus wonderin b/c i have a raptor with alba pipe, k&N powerkit, high comp. pistion, dyna ignition and lots of weight reduction with wheelie bar runnin in 1/8 mile asphalt, and it turns 8.3's , and i jus bought a banshee and i think i can make it faster than the raptor
  15. Which Quad is faster in a drag race? The Raptor 660 or the Banshee
