tijoe696
Everything posted by tijoe696
  1. My head is ok ! When I saw this, I changed my cool head for my stock head. I have 110 psi with my cool head and 75 psi with my stock head. I think ...My compression tester is ok. I tested my snowmobile with ! 140 psi .. OK My engine run like shit .. I have a ping noise comming from the cylinder with both head. And I don't know why, I have the same jetting and it running lean. It's the first time its happen to me. The arrows are in the good way !! Sorry for my english ... I speek french. I live to quebec city in Canada. Thank you a lot guys
  2. I don't know what to do ! I'm very confused.
  3. My dealer honed my cylinders and they gave to me right piston for my cylinders. Everything's new, Piston, rind, pin, bearing .... And my head is A1. Thank you
  4. I got 75 psi after a rebuild on both cylinders. My compression tester is good. I ran 1 hour with him. It's enough to seal the ring ? Thank you !
  5. Hi ! Which is the most beautiful graphic kit ?? Post your opinion guys !!
  6. Sorry, With T5 pipes
  7. Hello, I bought Mukini 28mm carbs. What is a good main/pilot combo to start out with on the 28mm? My mods are, -K&N air filtrer -No Lid -V-Force 2 -Noss Head with 20cc domes - + 4 Degree key -Sea Level Thank you
  8. Is there a way to install my v-force ?? Thanks
  9. I have also k&n air filter !
  10. HI GUYS ! I need help. What jets and pilot should I be running? Standard carbs Sea Level T'5 pipes V-Force 2 Coolhead noss with 20cc domes airbox lid off Thanks a lot !!
  11. Thanks guys ! I will going with a noss head with 19cc domes. I Will running with prenium fuel (91 octane). Am I OK ?? at sea level with 19cc domes .
  12. My alt. is Sea Level
  13. Which is the best cool head for my banshee ?? Pro desing or noss machine ?? Thanks !
  14. I have a 2004 Banshee. My mods are as follows: Toomey T-5 Pipes V-Force 2 reeds Boost Bottle Dura Blue air filter 1/2 Reed Spacer what is the best jetting setup for my banshee ?? Thank you
