westtxdiver
westtxdiver's Achievements
  1. Thank goodness someone makes after market j arms. hey sanddragon do you have a web site or pics. of the j arms. thanks west
  2. I need uppers and lowers. What do you want for them? Anything will help. Drop me a line at [email protected] thanks
  3. I have a stock 1988 j arm banshee. I have totally rebuilt this thing. Every bushing bearing and seal has been replaced. It is now time to replace the ball joints. There is a lot of slop in the balls is there a way to replace the ball joints with out dropping another $1000 for oem j arms. I also thought about buying a used a-arm banshee frame and buying aftermarket a arms. Sure would be a lot of wasted time if i have to go that way. any help or suggestions would greatly be appreicated. thanks alot westtxdiver
  4. thanks guys for all the info. Does any one know where i can get some new aftermaket j arms with chrome moly balls?
  5. Where did you get the new j arms. are they stock or aftermarket???? it
  6. what part is smashed the plastic or the metal barbs in side. if you cant find a new plug. go to radio shack and buy a male an female plug with that many prongs and make your own. It will come with the metal barbs and all you have to do is cut the wire crimp the metal plug and push metal plug in to correct hole in new plastic piece until it locks in place. then plug male and female together and you still have the disconect function just not in a factorty style plug. That is what i did for my key switch. worked great good luck.
  7. i took my stator cover off lots of water like most people experience. but here is the deal. it is a stock stator. Bike runs fine never mises a beat, but head lights, and brake light and kill swith dont work. Will the bike still run if you stator is bad. If so can anyone explaine the light situation.
  8. I have replaced every bshing bearing and seal on this bike it was a total rebuild. Its just getting to the point that i have to much in it. And i haven't even touched the engine. Was hoping to be able to just buy new ball jointsnd weld em in. thanks guys.
  9. how much slop in your a arm ball joints is to much? Is there any way to replace them with out buying new arms? Thanks for the help guys...............and girls.
  10. I have already tried energy suspensions. The guy i talked to said he couldn't help me. But i might have 2 boots that are in desent shape as long as you have the keepers. They arn't mind but beats what u have. I also have a guy in calf. or wash. that has a lot of used low hr parts. I bought the rod and rod ends for $60 only had 10hrs on em. Let me know if i can help you.
