theblackone
Everything posted by theblackone
  1. You were right on ,thanks alot !I dont get on here alot because I dont have a Banshee ,but everytime I needed help for my buddy you guys always help out .Thanks again!
  2. Sorry about that its going into the air filter !
  3. My friends banshee is doing some wierd stuff were sure its the carbs ,heres what its doin its not getting feul to the left side carb its going to the intake instead of the motor any help would be appreciated!thankx as always!
  4. Ok tried diconnecting the tors and it didthe same thing all was good for about 30 seconds then it started popping it will no longer idle and only pops when you give it a lot of throttle and let off of it ,it shoots a flame out about 5 inches or so!Any new ideas will be much appreciated thanks in advance!
  5. My buddies Banshee is doing the same thing ,He doesnt have the tors removed so we are going to try to disconnect them later today and see if this helps,did you check the hose that connects the two carbs?I dont know from experience ,but from reading so much on this forum lots of people have said this hose has come off causing this problem.Good luck hope you figure out whats wrong with it so then maybe it will be the same thing for us.
  6. OK the plug boot has been replaced still the same problems !How do I check the tors?Sorry for the dumb questions.
  7. Thanks for the reply ,I will check this stuff out tomorrow and let you know!Thanks again!
  8. First of all Im new here so Hello,Now a good friend of mine has a 02 banshee with these mods :bored 20 over just done ,Vforce 2 ,FMF full exhaust ,boost bottle ,ricky stator set on 4 ,but has tried every position and has new stock carbs I couldnt tell you the jetting but I can find out if it helps ,this thing ran great up till about two months ago it started only running on the right side you could tell because there was nothing coming out of the exhaust on the left side not to mention it was falling on its face and popping like it was trying to cough up a hairball so he took it to the dealer they did a 20 over bore with new pistons the whole nine yards ,he got it back and it ran great ,until it got warm then it started doing the same thing as before nothing on the left side and spitting and popping like crazy ,its now getting worse and doing it all the time so its parked and hes only rode this thing once since he got it back .I was hoping someone could help us out with a suggestion.Thanks in advance!OH yea weve tried new plugs over and over same results .Ive also tried switching the plug wires it seems to go to the right side when doing so ,also the plugs are both wet,and Ive tried another CDI and coil no change ,help!
