shockwave67
shockwave67's Achievements
  1. Motor was runnning when pulled. Thats what I was told. Its been sitting for 6 months in his house and looked a little dry but no rust. I sprayed oil and wd40 in it and compression was 180 when I quit kicking it. Its a 2000 motor and frame powder coated blue with the following on it, 409 TonyDoukas motor with receipts. Crank welded,mx ported,boost bottle,pro design intakes,spacers,delta force II reeds, 28mm carbs,cool head,polished side covers (2) kill switch,wiring,cdi,coil,steer stem, radiator,kick starter,billet oil stick,gear lever,master cylinder and brake reservoir,coolant reservoir,inline fluid cooler on radiator hose,stock swingarm,chain,most bolts are on it for a-arms,etc. Worth over $2000 easily parted out. $1500 cash for all or the motor local pickiup preferred. I will ship everything but the frame. 919-550-1765hm North Carolina here email at [email protected]
  2. Motor was runnning when pulled. Thats what I was told. Its been sitting for 6 months in his house and looked a little dry but no rust. I sprayed oil and wd40 in it and compression was 180 when I quit kicking it. Its a 2000 motor and frame powder coated blue with the following on it, 409 TonyDoukas motor with receipts. Crank welded,mx ported,boost bottle,pro design intakes,spacers,delta force II reeds, 28mm carbs,cool head,polished side covers (2) kill switch,wiring,cdi,coil,steer stem, radiator,kick starter,billet oil stick,gear lever,master cylinder and brake reservoir,coolant reservoir,inline fluid cooler on radiator hose,stock swingarm,chain,most bolts are on it for a-arms,etc. Worth over $2000 easily parted out. $1500 cash for all or the motor local pickiup preferred. I will ship everything but the frame. 919-550-1765hm North Carolina here email at [email protected]
