416stroker
    416 ex +4 stroker curtis sparks pipe...ect
416stroker's Achievements
  1. Smart Parts impulse w/invision eye Chrome drop foward 5000 psi nitro tank 3 20 ounce tanks 1 face mask jt barrel cover Asking $650 worth over $900
  2. a smart parts impulse paintball gun with the invision eye, with a drop foward and a 5000 psi nitro tank and 3 20 ounce tanks. guns is only 6 months old, used only 3 times...mint condition $650 worth over $900
  3. any one for 550 worht 1200
  4. go to http://www.imagestation.com/album/index.html?id=2129276908 for pics copy and paste the address
  5. This is a fairly new t-maxx 2.5 that has insane amount of power and extras. This truck will pull wheelies with the tap of the throttle. The following is on the truck, Sirio .23 Medium Block Motor, Robinson Vented Racing Flywheel, MIP clutch set on high rpm setting, Barnburner Custom Dual Exhaust, Fail safe, 72 Tooth Metal Spur Gear, Intergey Shocks With Rezzies. The following will come also with the truck, The 2.5 motor that is In good running condition (NO clutch bell or nut to hold the flywheel), Dragon rc K& n filter system, Stock exhaust, Stock air filter, Glow plug warmer with the gauge to tell whether or not the plug is good, Two Mcoy glow plugs, stock rims, blue rpm rims with panther paddles, the stock tires are mounted on offset blue rpm rims. The car has only 1
  6. hey it dose do around 95 i beieve because i was with him in pennsylvnia and in 5th gere the gps said 89 so it is capiable..this is a very sick looking quad too
