IDAHOSHEE
Everything posted by IDAHOSHEE
  1. You nailed it, left plug wire cap conection was loose. Thanks
  2. Update.......... Ok, so I found the cause of the cutting out, air gap was fine (.018) so I started checking coil, plug wires and so on. Found loose connection in left cylinder plug wire connector. Repaired that and the cutting out is gone, now just falls flat so I will mess with the jetting alittle more. Yes it pulls real hard until it falls flat. So just down to alittle more tuning at this point I think. Thanks again for all the ideas and help.
  3. They are the new castings. Thanks for the ideas. I am going to pull the cover tonight to check the air gap. Thought I was on the mark but who knows.
  4. Thanks for the imput guys, I will pull the cover tonight and check the air gap.
  5. Had;nt changed the sig yet, running duel 39's , tried from 152 mains to 188's
  6. Looking for some help, just built a Vito's 421, 20cc domes, 160 lbs compression,shearer in frams, 155 main jets in new 39mm kein pwk's. runs great until it reaches higher rpm's then seems to cut out and sputter, falls flat on it's face. Have tried going both directions with jetting does not change the cutting out. Have tried timing from 0 to 7 deg advanced, does not change the problem. Any advice at this point would sure help.
  7. I can shift fine, it's like I run out of travel with the shift lever, it tops out but has not gone into gear. Thanks for the idea though. :biggrin:
  8. I am having a hard time hitting 2nd gear, when on the throttle hard. I have done the shift star mod and it shifts great on normal to moderate acceleration but on hard accel you can feel the shift lever top out and 9 times out of 10 it will not go into 2nd gear. all other gears are great all the time.
  9. Wilder, Idaho. About 10 mi. east of the Oregon state line. 6 hrs to St. Anthony, 8 hrs to Florence.
  10. Shit don't stop there, DID HE GET THE BUCK???
  11. Actually if you had to ask that question, i think you are better off on a 4-stroke.
  12. Ride it like you stole it !!!!
  13. While grocery shopping.... A guy goes to a supermarket and notices a beautiful blonde who waves at him and says hello. He's rather taken aback, because he can't place where he knows her from. So he says "do you know me?". To which she replies "I think you're the father of one of my children." He thinks back to the only time he has ever been unfaithful and says... "My God, are you the stripper from my bachelor party that I laid on the pool table with all my buddies watching, while your partner whipped my ass with wet celery and then stuck a carrot up my butt?" Suddenly looking very uncomfortable, she said "No, I'm your son's math teacher."
  14. Amen, why get on here and ask an opinion if you are only going to try to justify buying one. BFS, if "YOU" want one "YOU" get one. If you ask for advice, USE IT !!! dont counterdict everything you are told.
  15. I may have missed something but what happened to Led? Mudfool aka Joe Dirt
  16. Pimp, come on now, thank the lady.
  17. Brooke, babe you rock. That takes the words of all of us and sumed it all up.
  18. you think your friends like you when you say
  19. Hey duece, I have read this entire thread and have not felt insulted by anything you have said. Actually I was inspired. Pimp, speak for your self. This "poor person" has worked very hard for every thing I have. I may not be as rich as others but am proud of what I do have. If for some reason you feel not worthy, my advice, work harder!!! Get off the government aide and food stamps, dust off your work boots and get a f*cking job that will give you that "worthy" feeling.
  20. Coming from Idaho, will be in Florence july 3rd to the 9th.
