oneday
Contact Methods
  • Website URL
    http://
  • ICQ
    westland, michigan
  • Interests
    silver lake sand dunes
    "93" BLACK/WHITE, +4 SWINGARM, V FORCE POWER REEDS, REED SPACERS, K+N FILTERS, 300 MAINS 27.5 PILOT, INLINE COOLER, t-5's, noss head-21 domes
oneday's Achievements
  1. could my idling problem be caused by a slightly bent needle? on 1 carb
  2. this may be a stupid ? when the bike is at an idle, if i snap the throttle the rpm's raise then drop to almost an idle ( holds for about 4 secs) then returns to a normal idle. could this be a float adjustment? thank's for any feedback.. :shoothead:
  3. i have a "93" shee with some mods, curious on how to set the jetts (pilot/ main), needle, air screw. mods r as follows: stock bore noss head 21 domes v force reeds w/ spacers t 5's sparky spark arrestors stock carbs stock needles ? k+n clamp ons i ride only at silver lake sand dunes in michigan (sea level) any starting points would help thanks. :shoothead:
  4. what size fuel line on stock carbs / fuel filter necessary? :baseball_wibble:
  5. i need some help.. 93 banshee just replaced rings, toomey t5, v force reeds, bolt on k+n filters, jetting = 320 main 32 pilot, i run on the dunes at silver lake (michigan), after running for 10-15 min pipes turn blue just past exhaust ports on jugs. bike runs very strong just concerned if causing any damage?? thankx oneday
  6. i am in the process of installing new rings on my banshee, however i am not sure of the replacement size? on top of piston it has an arrow obviously showing you the way the piston is installed, it also has the letter "G" stampped on it. ANY IDEAS OF THE SIZE? pistons/bore look good, no scratches or visible damage. THANKS ONEDAY.........
  7. i have what i think is a stock 91 lt250r carb, according to suzuki scamatics model "h" ? if i get my hands on another one can i use it on my bike. p.s. what size is a model "h"?=mm? i know that there may be some mods needed
  8. hey guys anyone going to silver lake on oct 29,30,31? that is the last weekend right? let me know, oneday
  9. just curious if anybody was heading to silver lake for final weekend? ( also what identifies us as an hq member?
  10. i was just curious, i heard of getting a discount on the purchase of a noss head from this site for being a member? is this true? who do i contact to learn more? thanks oneday.
  11. a ? for everyone. does any one in detroit area know where someone might go to have there head milled? also how much milling = how much compression? thanks, new member ONEDAY.
