UnKonshisTheorys
Everything posted by UnKonshisTheorys
  1. sorry couldnt call, what are you lookin to get for the set? how much do you figure it would cost to ship to MI
  2. I need the top and bottom engine case if any buddy just happens to have extra "parts" layin around..
  3. how often do transmission gears go bad if ever????? its a 99 guy said it wouldnt shift any more and he had just replaced the clutch plates and springs...could it just be a screw up with the clutch or is it a possiblity that the transmission really is screwed
  4. How do you know when you are running to rich or to lean?
  5. aright thanks, i will just chuck them into the trash
  6. when installing new friction plates and springs are the rubber cushions absolutly needed or no?
  7. are they just a bolt up cage and go, or does it require rejetting or anything like that
  8. If you have the hush kit, or sparkys you should be fine, the max is 94 db, they randomly check and it only seems to be on holiday weekends, or when they have the hill climb
  9. Just bought a 96, it came in pieces, putting it back together and the pistons have a "N" stamped on the inside, guessing these are Namura. Is there and easy way to tell what size the pistons are. I have seen on wiseco that it is stamped on the top, and these others dont have that.... The cylinders dont need to be bored, i was just gonna hone them and replace pistons with some new wiseco, any suggestions?
  10. How much front and rear fenders?
  11. How much for the reed cages?
  12. Both Carbs! How much? Handlebar & rear grab bar?
