Hi Guys. THis is my first post on this awsome website. Unfortunatly its not one I wish I had to make.
Ive got a 2003 Banshee with PSI pipes, K&N filter, 21cc domes and billit head, Boost bottle, boyceen reeds, and a dynoport carb jetting kit (the one that comes with the longer needle valve.)
Heres the problem. When i look at the bike idle i only see exhaust smoke comming out of the one side of the bike, yet compression is the same in both and as far as I can tell the carbs are in perfect sync but im going to double check. So before I tear it all apart i want to hear what you guys have to say about the other problems.
1. It has a very unstable idle. It wont come down to idle all the time, it likes to keep reving out. I think i need a bigger pilot jet since im still running stock. Do you guys agree?
2. Just recently when you hit the powerband at idle the bike will just say in the powerband and even turning the key wont shut if off. Im guessing that the clip needs to be set richer because its running lean.
3. THe bike surges power its not smooth like a stock banshee is. Im guessing its all carburation problems.
However the bike runs for the most part very well. But these are the few flaws i want to get fixed up.
I hope someone on here can help whos gone thru the same thing.
PS.
This bike used to pull one bike lengh each shift on a DS650. Now ever since it started this reving out detonation, The DS650 will pull on me a little with each shift. My question is can running to lean, even though the bike feels fast and high reving, make less power in certain situations.
I dont care about beating the DS650, I just want this bike to perform the best it can in its layout.
Thanks a lot.
Martin.
