westtex_banshee
    1998 with tribal graphics, Toomey T5's with carb kit, Proflow design intake, Wiesco pistons, Works shocks
westtex_banshee's Achievements
  1. Shee is running again!!! Removed left carb and cleaned it up. Put it back together and both cylinders are firing. Still not running perfect. Loading up for some reason. Still in process of breaking in new top end. Maybe "loading up" problem will resolve once I can really put some gas thru it. Thanks for all your suggestions.
  2. Thanks for all the info. I'm spending tomorrow in the shop. I'll report tomorrow afternoon.
  3. What exactly is the CDI? What does it do and where is it located? I replaced the ignition coil with no result. thanks
  4. 1998 banshee with few mods. Was running perfect. Started sputtering. Left side cylinder is not firing. Can't figure it out. Last week replaced top end and yesterday replaced ignition coil. Have checked reeds and they appear OK (not sure what this means but when I removed reed cage, the intake port on right cylinder was moist and dry on left side. Could it be carb problem? Also, when I place my hand at the end of the silencer on right side you can feel heat - Nothing but a little amt of cold white smoke coming from left silencer...I'm lost and downtime hurts! Any help would be greatly appreciated
