summit
summit's Achievements
  1. I have a 1990 Banshee with fmf gold pipes and an in the box K&N filter. I have some questions. Is it normal for the slides in the carbs to be turning almost all black? Also inside the carb slides there is a hole next to the hole for the jet needle. The little bracket that you put on (with two screws) that holds the throttle cable will either cover the hole or leave it open depending on what position you put it in. Is the hole supposed to be open or closed? One more question is what temp should Banshee's be running at? Thanks
