AJS
Contact Methods
  • Website URL
    http://
  • ICQ
    INDIANA
    92,With 2-1 carb, Trinity stage 4 intake & head,fmf pipes, timing plate advancer, Trinity TT porting, K&N air filter.
AJS's Achievements
  1. fmf pipes, timing advancer.boysceen reeds
  2. I have ported cases and jugs trinity stage IV head and manifold with 35mm pwk 2 into carb. Right now I have a idle jet is 50 & main is 180. It seems heavy on bottom and maybe a little lean on top, Does this sound right. Thanks
  3. On the coil thing I switched plug wires and the left side still fouled. It just does not make sense.
  4. I completly took the carb apart before putting together this last time. I did a compression test before rebuilding it and it checked 150 both sides, havn't checked since the rebuild.
  5. Here's the deal. This past summer while doing some riding foulded a plug on the left side. Normally no big deal, put new plug and go, right. But the next time out on a weed end trip, foulded 8 plugs all on the same side. So when I got back went thru carb (2 into 1 carb) reeds, ended up boring and new pistons and rings crang seals split the cases, basically the hole 9 yards. But this weekend went out and after about a half hour fould a plug agin. Same side always the left side. Check the plugs and the right side looks perfect and the left side is wet. I tried switching plug wires same thing. You can have ti running for 5 mins and tell a difference in the temp of the exhaust pipes. also a lot more smoke comes out of the left side verse the right side. Need help Thanks
