The spacer plate is for port timing so the builder does not have to grind so much in the top of the transfer ports to get to the 130 degree open duration,(not enough wall thickness, will break through on a banshee motor to get it right)134 degrees appox is what you want with larger volume pipes,this does lower crank case presure slighty but not enough that you would notice on a banshee motor,the spacer has nothing to do with the head design other than more work to machineing the head, put a degree wheel on the fly wheel and bring to top dead center and check the port timing to make sure you are @ 79 to 80 degree`s on the exuast and @ 113 after top dead center on the tranfers,if this is close and you have tryed all jetting combo`s, most importantly richer cutaways, and you still have a dead spot check to make sure that the transfers have been ground the same on all of them,this where you go from 70 to 90 hp check to see that the upswept angle is no greater than 3 degrees and that the pitch is towards the center (stock sucks pitched up and back) if this is all good then check your head, put a piece of SOFT lead on each side of the top of the piston directly over the rist pin and roll it back and forth and measure the lead it should be .o40 on the outer dia and tapered up to thicker towards the center of the piston 1 degree,and 8 mm long, then make sure you have the piston on top dead center and
check with a burrette gage, or a sureange gage and check to see the uncorrected volume, it should be @16 cc ,this is good for 93 octane
