turbor
Everything posted by turbor
  1. whats the whp of a stock banshee? also how mutch whp in general would i gain by putting pipes and a kn filter? i cant find specs on the stock whp of a bansee nowhere, thanks!
  2. ok, i just put 300 mains in it, and did a plug check and its right on!!! and it pulls alot more too!. i adjusted the needle one notch ritcher than stock, the midrange is awsome, i left the pilot stock (25) but i have a slight hesitation right off idle so i need to play with screws right? i have no clue witch srew is the air screw and witch screw is the idle speed screw? Also when i'm wide open in 5th or 6th and come back to idle right after i noticed the idle is a little faster than normal for a few swconds, could that mean i'm a little ritch on the mains?
  3. toomy banshee, i still dont get the way you say it lol, you need to put the clip one more notch closer to the taper end so 4th clip from the top. The way i read both your post youre suggesting i put the needle lower and putting the clip one notch closer to the flat end, that leans it out.... Anyways, i did put it on the 4th clip from the top today and it did indeed like it i'm running a 280 main, but i'm pretty sure its lean on the top end because it revs but i dont feel any power and my pipes still are pretty dry in the end when i come back from a ride compared to stock when they always where oily at the tip. Is there a big difference from a 280 to a 290 or should i switch to a 300 right away?
  4. what? you are suggesting i lean out the midrange by moving the needle clip one notch higher? i wanted to move it one notch lower to ritchen it no?
  5. ok i live in montreal canada, and have no idea of elevation, my shee is a 04 bone stock except for a kn filter and the snorkel removed. can anybody tell me my elevation and how to get it? i have been told by a local shop 280 mains and stock pilot ,stock needle positon (3rd?). The more i read here the more i think this will too lean. im not sure if i should change the pilot to a 27.5 ? but im almost positive i should start off by moving the needle to the 4th clip and a 290 or 300 main. In my head if you add pipes that are supposed to help you make more power in the midrange, than you need to add fuel in the midrange(needle) if you dont toutch it, youre not msking alot of extra power in that area over stock? Also the right pipe is VERY close to the lower rad hose on the base of the motor (like 1//32~1/16) is that dangerous? will the hose eventualy melt? How do i remove the switch assy (what the hell is that for anyways) on top of the carbs to acces the needles? thanks guys, just got my banshee a few weeks ago and ready to start playing on it!
  6. I just bought my 04 shee and it is hard to start when cold (i do use the choke) like 10-15 kicks, when it is warm, it starts first kick... is that normal? what could cause it? i run 94 octane fuel with klotz oil mixed at 40:1
  7. sent you an e-mail, saw your pics, i'm taking them, will send you money tommorow, so i guess theyre sold!
