D'Lo
Everything posted by D'Lo
  1. 1995 Yamaha Banshee Team Alba Graphics and Ceet cover. EVERYTHING IN LIST IS CHROME:Grille, handlebars, brake pedal, shifter, Moose A-arms, Laeger's extended swingarm, P.E.P wide axle, tie-rods, brake block off, front suspension. Holeshot rear tires, DG bumper and grab bar, new UFO plastics. Sharp!!!! For sale!!!! Must See to appreciate! $3000 Linton, IN Go to........ http://www.albaaction.com/atv/Yamaha/sport/superbanshee.htm The same color and graphics as the one pictured , i have holeshots no paddle tires, and my frame is painted royal blue
  2. I'm new here so i don't know if this question has been asked or not. When I start up my 95 'shee, it revs up high as hell, but when i shift it into gear and ride around it settles back down. changed the plugs so many times drainded the gas and carbs, still does it. It is stock engine-wise and I run Klotz mix at 32:1. I have been told if mixed gas(especially Klotz) seperates and you burn either straight gas or oil if it has set a while and seperated. would this make it rev up high like that? but even when i shake the hell out of it it still revs high?? need help quick!
  3. I'm new here so i don't know if this question has been asked or not. When I start up my 95 'shee, it revs up high as hell, but when i shift it into gear and ride around it settles back down. changed the plugs so many times drainded the gas and carbs, still does it. It is stock engine-wise and I run Klotz mix at 32:1. I have been told if mixed gas(especially Klotz) seperates and you burn either straight gas or oil if it has set a while and seperated. would this make it rev up high like that? but even when i shake the hell out of it it still revs high?? need help quick!
