chromeshee
Everything posted by chromeshee
  1. THANK THE LORD!! i finally got it.i got to looking at it and the bleeder on them old style calipers is pointed out instead of straight up like the 91 and up ones.i took them off and held them up and tapped them with a rubber mallet and blead them till finally all the air started coming out.it still took awhile and a lot of tapping and moving around to get all the air out. maybe this will help someone else,thanks for the help guys
  2. thanks for the help guys, i have already tried pulling a vacum on it,i have been doing that for years also and its never let me down either until now. i did leave the bleeders open last night but havent tried it yet. i havent replaced the bottom rubber lines or calipers,is there any way they could be bad? the bike was mostly apart before i started so i dont know if the worked before, thanks again please keep thinking
  3. i always put clear fuel line on the end of the bleeder,that way i can see if there is any air,and when all the air is gone it still wont pump up. i worked on this thing for 6 hours today,it is beating me and i dont usually give up on anything!
  4. THANKS FOR THE REPLEY,AND YEA I HAVE DONE ALL OF THAT
  5. i feel stupid asking but i have tried everthing.i have a 89 shee i am rebuilding from frame up for a guy.i was putting the front brake system back together as usuaul. i cant get them to build any pressure. i have changed 3 master cylinders,cleaned the lines several times.i changed the metal lines and the top divider block and line.i have gotten all the air out. i can pump the brake 15-20 times and crack the bleeder and the fluid dribbles out. if you pump it up and dont bleed ,and then just let lose of the handle the fluid squirts back up through the master cylinder.that makes me think it clogged somewhere,but i have cleaned several times! has anybody ever ran into this? i have built several shees and never seen this happen
  6. oops,ENGINE,there got it that time
  7. check your engineend,you have a skirt broke on a piston or a rod bearing gone,is it making a rattling noise?
  8. DID I UNDERSTAND YOU GUYS TO SAY HE HADNT EVEN ROD THE BIKE? HE NEEDS TO THROUGH A LEG OVER THAT THING AND RIP THE THROTTLE ONE TIME!HE MIGHT REGRET ALL THIS CRAP HE STARTED! OH YEA ABOUT THE 2 INTO 1 I AGREE,DONT BELONG ON A SHEE
  9. those were mine and they were legit,you guys missed a good deal !!they were fast !
  10. bruce can i ask a question? if you wanted low end WHY THE HECK DID YOU BUY A BANSHEE! you should have got a 4 strke,banshees are made to SCREAM DUDE!they dont have low end from the factory and it dont get much better,i have dealt with rob and john on nearly a dozen engines they do all my porting now,every time i put one together it makes killer power.i have tried several different others compaines also,nobody has made as much power as those guys or been as professional. if they offered to buy your gas and give you moneyback,why the heck are you whining and bashing them?guys like you dont deserve a banshee,ever heard of a 400ex or raptor,you can putt around on those
