tizz78
Contact Methods
  • Website URL
    http://
  • ICQ
    Indiana
  • Interests
    ATV's , computers , 60's era muscle cars
tizz78's Achievements
  1. Left cyl is lean(The side with the deep pit) . I'm not sure if it's the head or not . It kinda seems like a good measure to replace it though . Right plug seems to have more oil/fuel on it than the left . Left is turning white(Lean mix) and has fewer deposits on it . If I leave the choke on all the way it will at least smoke from oil , chocke off you'd better shut it down fast before it's too late unless TORS is on .
  2. What is needed to replace the T.O.R.S ???
  3. Hello everyone , welcome to my problem . As the topic states , I have a Banshee with a major problem . It had a top end put on and now you can only start it with starting fluid and then it just raps out . The head has a deep pit on the left side , but both cyls. have 120 psi . I've sprayed everything I can find with carb cleaner and found no vacuum leaks . I've also cleaned the carbs , no help . The throttle slides are down where they should be I think . The T.O.R.S switch was replaced on the right carb because it broke and wedged the throttle open on tha side , not sure how many turns they(screws) should be . I'm not sure if the air screws on the rear of the carbs are set right or not . Could this be the problem ??? If so how many turns out should they be ??? Please help !!! Thanks!!!
