Hey guys I was just wondering what would my top speed be. Can you give
me an estimate?
Race cut plastics
Bored .080 over
wiesco pro lite piston
ported cylinders
34mm keihin carbs
straight filters
boost bottle
carbon reeds
toomey T3 pipes and silencers
14/42 gearing
22"tires
Hey I know that this has been asked before but I want to know my top speed.
What would you guys think???
Race cut plastics
Bored .080 over
Wiesco Pro lite piston
Ported cylinders
34mm Keihin carbs
Straight filters
Carbon reeds
Boost bottle
Toomey T3 pipes and silencers
14/42 gearing
22" rear tires
Hey guys I am going to go trail riding today with a boy who has a warrior, I have
a modified banshee, you cant go fast through his trails and there is alot of mud and
hills to climb will I be able to keep up with him and will my banshee make it through that stuff.
Hey guys I was putting my carbs together on my banshee and on one I
tightened the choke down to tight and it stripped the threads does anyone know
where I can just buy the choke part. I have 34mm Keihins.
Hey well I own an 87 banshee that has been bored .080 over, ported, and has toomey pipes,boost bottle and 34mm keihin carbs but what I dont know is what
to set the carbs too,pilot screw,needle jet, main jet, floats please help.
Hey for some reason my banshee sounds like its backfiring it does it alot, you keep
hearing a ping, ping..noise from inside the pipes. I have the right oil/gas mixture in it and new spark plugs and cleaned the filter could it be the carbs please help?
Hey everyone I am new to banshee but know alittle common since about
anything and what is wrong is the banshee has 34mm keihin carbs on it and
the bowl hits the little clutch plate I dont know what its called but its right under
neath the carb bowls and what it does is when you let the clutch out it hangs on
the bowls. The bowls are setting to LOW. Please help
