SnoRipper
Everything posted by SnoRipper
  1. I need the torques specs for the case halves, side cases, and for the clutch. Or if you can post a link that would be great. Scott
  2. Any of you know a part number for the crank seal? How easy is it to install?
  3. Can any of you post a How to on changing it out? like simple stuff gaskets needed, Do i have to take the cylinders off, that kinda stuff thanx Scott
  4. I was riding yesterday everything normal plenty of power everything is great. I land off a jump and turn left and gas it as im on the way back to the truck i lose all power and the righty cylinder only pours out white smoke! Left cylinder is fine and it still runs. I thought it was rich and i had fouled a plug but whe i tipped it up on teh grab bar about 1/8 quart of tranny fluid came out the right side silencer. Muffler packing was soaked in tranny oil. What do i need to do to get rolling again. I pretty new to shees but know my way around tearing down a motorcycle engine. Engine mods Pro Design cool head 22cc Big bore domes, 409cc big bore kit, true and welded crank w/ hot rods, 28mm mikuni flat side carbs, Paul Turner mid range pipes. 4degree timing key, barnett clutch kit (stock basket) If i had to guess id say it was the gasket between the case halves is blown. Need help asap!!! Scott
