SYRacingInc.
SYRacingInc.'s Achievements
  1. What is your email address? It is set to private so i cannot see it.
  2. Send me a pm and ill send you the pic and details. Thanks
  3. As it says, buyer pays shipping, $175, springs are white. Excellent condition.
  4. It will come apart fine if you if you follow your way of thinking.
  5. You can rent a spring compressor from your local auto zone, etc. They require the price of the tool for a deposit, but you get it all back when you return the tool.
  6. Run it with 93 octane and check for detonation. If it is detonating tt will sound like little gremlins are inside your cylinder beating it with a hammer. I highly doubt youll require anything more then 93 octane. For jetting.......be safe. Start with 300 mains, stock pilots, and put the needle in the middle.
  7. Sold my autococker last year for some banshee parts.
  8. That is an impossible question to answer, it is all preference. I have seen alcohol bikes run awesome at 125psi, and 170psi. Same goes for gas, all preference. Cranking compression isnt as important as some other factors.
  9. Adding spacers will increase the crankcase compression ratio which will give a more mellow power hit.
  10. I tried the search option, it didnt work correctly.
  11. Anyone know where i can buy a kit? How much? Thanks
  12. I wouldnt even sign a contract like that if i was partners with my own father! Dave has continuously let down his die hard customers.....
  13. I believe he is talking about the slides.
