bigstink
Everything posted by bigstink
  1. i would be very interested in buying it email me at [email protected]
  2. go to the powdercoating place and check out the options they got, the guy whol lives around the corner from me powder coats and i have seen a mix that is black with a little red sparkle, that would be sick as hell
  3. all white and a white and silver cascade seat is mad stez
  4. i have boyesen reeds right now and was wondering if i should go with v-force to add more power. thoughts???
  5. i am afraid to look at it, what is the picture of?
  6. my buddies have just started up this clothing company, i wear there shirts when i ride alot and get alot of compliments, just keepin you guys posted on some tight stuff www.enemyofevilclothing.com
  7. how much power would i be losing from an air leak
  8. would anyone know? it would help out alot
  9. if there is an air leak does this mean im losing power, cause it cant be good, let me know
  10. bigstink
    Drag Paddles
    cant find anywhere drag paddles with 10 or 12 scoop, anyone know where to get them
  11. on my fmf sst pipes i have blueing on the base of one pipe where it comes out of the engine block, but not on the other, the other pipe turns a light brown kinda at the base. engine runs fine, very fast, is my compression off??? i just got the motor rebuilt a couple months ago but am baffled by this problem, thanks for your help. stink
  12. well this banshee i saw at the show was straight drag banshee, i asked the guy if it would get too hot and he said no they hold up fine, i havent had trouble. Whats the worst that could happen?
  13. ive seen clear coolant hoses on eba before and thought they looked pretty trick and wanted some. I went to the arizona sand expo and i saw many banshees there with them on and asked about them, the guy said he just got the hoses at home depot and the max temp on them was 185 degrees. I came home and did the same got the hoses and put them on, along with the blue engine ice radiator fluid. I looks way tight and havent had any problems with them at all, they get wat soft when i am riding but all hoses do. I just thought i would tell people about this cheap trick way to make you banshee stylin.
  14. thanks that is perfect
  15. is the sand paper really necessary? I mean i did a good job scotch briting it now im ready to paint. im painting it this ice color(gray colorchanging from blue, green, red, yellow) im new at this but ill try to post pics when i am done
  16. so what is the process once you have everything ready, the sandpaper, scotch brite and paint? im ready to do mine just need some clarification.
  17. nice, but when most people wire those how do they wire them, were do you connect them to, the tail light? or do you run a switch up to the front somewhere?
  18. Im thinking about lighting my engine and ground a little up with neon/ regular lights. Any suggestions for which lights to use, and where to set them up for best looking. Also, wiring them to take less power away from the head lights if there is anyway. thanks
