Tucan Sam
Everything posted by Tucan Sam
  1. Both you and Kayne West sound fruitier than my cereal... You have failed to grasp the concept of politics, just as you have failed in life. Step away from the computer and go drown yourself in your toilet.
  2. I bet it got shinier after all those beers you drank Do you have access to an air compressor?
  3. A stroker crank is a special crank that increases the stroke of your engine. When you increase the stroke the piston will ride higher and lower than the stock crank. Which is why you have to run a spacer plate or special domes to run a stroker. Hope this helps. And remember to follow your nooooose!
  4. The +4 crank will add some torque and smooth the powerband a lil. If youre worried about reliability you can use a long rod stroker. Hope this helps and remember to follow your nooose!
