03shee2003
Everything posted by 03shee2003
  1. how far is that from hazleton?
  2. just looking to see if there is any riders that like to get out on sundays.Does not matter banshee or not. just looking to ride.
  3. what about using the stock 14 front sprocket and using a 42 (stock would be 41) for the rear. will this make any differance for helping me get threw trails at slow speeds.
  4. try using 100% silicone oil. i used my rc car shock oil 100 weight.works great.
  5. thanks for all the great replies. keep them coming.
  6. thanks for all the replies. i was told that the higher octaine burns cooler.
  7. does the cv system work. i cant see why one carb that is 33 mm. could replace two 26 mm. carbs. and if it is better with the one larger carb. then why do they suggest to use dual 33 or 35mm carbs for the higher horse power engines.? has anyone on this site personaly tried the cv system with 33mm carb. (not the 35mm)?i would like to know so i can decide to get one. the more replys from anyone who has tried this carb. set up would realy help me to decide if it is worth it. thanks.
  8. could someone explain how you get detonation problems with high compression and not enough octain in the gas.thanks.
  9. hey guys, i am looking for the nos machines web site. i would like to orde a head for my 03 shee. any other suggestions about this head. thanks in advance.
  10. i'm looking to buy a set of rims (and tires if neccasary to fit the new rims) to give my banshee a bit more ground clearance is there anything out there?
  11. i'm looking to buy a set of rims (and tires if neccasary to fit the new rims) to give my banshee a bit more rear ground clearance is there anything out there?
