96shee84z28
Everything posted by 96shee84z28
  1. are any of you guys taking creatine? i've been on it for about 2 months and i thinks its workin pretty good. i'm 5'8" and i was 165lbs b4 i started and i am now 175. and my bench went from 195- 245. the only thing wrong with it is that it makes me cramp up spmetimes when i'm workin out but if i get enough potassium in my system i'm ok.
  2. DO NOT RUN A UNI FILTER WITH NO OUTERWEAR! i did this and it sucked sand into my carbs and they kept getting stuck wide open.
  3. you need to run higher octane gas... i did the same thing but i was running 20cc domes with pump gas and it put a hole right through the pistons. i started running av gas it about 110 octane and it runs great now.
  4. what exactly is roostfest?? i've been to dumont but whats the big deal with this date?? i think i might be goin that weekend
  5. I'M NOT SURE BUT I THINK ITS .080 OVER
  6. i hate the flats but i really like pad 4.
  7. what kind of riding do you do?
  8. i'm getting extreme haulers which from what i heard will be fine. and i live really close to hisperia so i should prolly look more into that. will it cost more than $400?
  9. whats the diff between the skat-trak exreme haulers and the skat-track haulers i'm lookin to get some new paddles r these goin to be good for me?? i'm into racing up hills, sand drags and i do some dunning.
  10. how much would a good port job be?
  11. hey guys i just got back from glamis (sand) and raced in the drags. i thought i'd do ok but i just couldn't hang with some of the banshees there. what should i do to get my shee faster. my mods: t-5's, 2 into 1 uni filter, coolhead 20cc domes, vforce reeds, bored .040, hotrod crank, no tors, barnette clutch.
  12. hey guys i just rebulit my top and bottom end. whats the best way to break it in??
  13. if you get the 20cc domes do not run pump gas. i learned the hard way that pistons with end up with a big hole in the middle after a few rides.
  14. oops.....
  15. heres what the piston looks like....
  16. so what should my jetting be with these mods?? my mods t5s, coolhead 20cc domes, 60mm pistons, vforce reeds,toomey 2 into 1 uni filter, and a few other small things
  17. so if i run av gas there shouldn't be a problem?
  18. my jetting is whatever the t-5 jetting kit said to run i haven't changed it after that
  19. i just rebuilt my top and bottom end with 60mm wiseco pistons and a hot rod crankshaft. i went to glamis and just puted around to brake it in. i ran about 4 tanks of 91 octane gas mixed at 36:1 and on the 5th tank it all the sudden started bogging out and died so when i got it home it had a hole in the middle of the right piston. why the hell did this happen and how do i prevent it. does this have anyting to do with the 20cc domes??? my mods t5s, coolhead 20cc domes, vforce reeds, uni filter, other small things.
  20. hey guys i've always wondered how much hp my shee can make and what my top speed should be is there some kinda equation or can you guys give me a rough idea..... thanks. my mods are t-5's, toomey 2 into 1 filter, no tors, pro design coolhead 20cc domes, vforce reeds, bored 40 over, stock sprockets.
  21. hey guys i just bought a new hot rod crankshaft with new main bearings. and i dont know what to do with the tiny ball bearing that is on the outside diameter of the right hand side outer bearing. what keeps the outside of the bearing stationary? do i only need to use the bearing clip? my old right side outer bearing doesn't have the stock pin thats shown in the manual. any help would be great, thanks.
  22. hey guys what do you run the oil fuel mixture at in ur shees. i've been told 50:1 and like 36:1 does it matter if you have mods or not? thanks
  23. hey guys i just messed up my connecting rods and i'm buying some new ones. what are the best brand out of these 3? niks/pro-x, ims pro series, or hot rods?? thanks
  24. i'm soo stoked i just got a pro design cool head with 20cc domes and vforce delta 2 reeds. think my quads goin to go a little faster.....lol
  25. hey guys what would happen if i ran pump gas with 20cc domes??
