death_merchant
Everything posted by death_merchant
  1. I have a black and red 2003 Banshee. All stock except for Vito's Performance 3/8" reed spacers. Approx seven tanks of premix through it. Clear title. Always ran Mobil 1 MX2T full synthetic two stroke oil mixed 32:1 with premium gas. Valvoline tranny oil with Lucas oil additive. Banshee was auctioned on eBay, but high bidder doesn't have the cash to buy. ABSOLUTELY MUST SELL!!! $3,500 firm. Located near Springfield, IL 62704 follow the link below for pics... http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2448251549 email: [email protected] cell#: 217-652-0671
  2. I forgot to mention in my original post that I have checked for air leaks around the engine. I used a can of ether and sprayed all around the carb boots, balance pipe, intakes, head and base gaskets, and crank seals. The engine continued to purr without picking up any rpm's whatsoever. So there shouldn't be any air leaks. Is there such a thing as an internal leak of coolant into the combustion chamber(s)? The coolant system was overfull and therefore overpressurized...
  3. I just recently sold my old '87 LT500R Quadracer and picked up a stock '03 Banshee. I got it from the local repo man with almost no hours on the quad. I have no idea what kind of break-in period this Banshee received, so I took it easy on her for the first tank of gas or so. Since then I've been riding her pretty hard (drag racing my friends, cross-country, and racing around some farm ground). Each time that I take the Banshee out she develops a hot idle problem. After about ten minutes she refuses to idle down when the clutch lever is pulled in. She also backfires occassionally. I'm a 240 pound, fairly aggressive rider. The Banshee is stock as a rock. No mods whatsoever (yet). I run Mobil 1 MX2T synthetic two-stroke oil at 32:1 with 94 octane premium gas. The Banshee seems to have good compression (as felt through the kickstarter), but I've spent most of my time on a Quadzilla, so it's hard for me to judge what is normal for a Banshee. There was a problem when I first brought the Banshee home...the previous owner had overfilled the coolant system. The first time she refused to idle, I did a quick check of the engine and saw antifreeze dripping off the frame. The engine hadn't overheated, but the system was so full that when the engine warmed up, the coolant expanded and leaked out at the radiator cap. Any ideas about what may be causing my hot idle problem???
