bansheeboy2004
Everything posted by bansheeboy2004
  1. Polished Rear marvin shaw 15.5 eye to eye. $175 shipped pics to big to post give me ur email i will send you pics.
  2. STOCK SHIFTER, BILLET SHIFTER, CDI SOLD open to offers on the rest
  3. no rod is for stock crank and the coil is off a 2001
  4. Basket have straight cut gears? You have the other straight one off the crank?
  5. Here's what i have - Polished marvin shaw shock 15.5 eye to eye- $200 Shipped -Polished billet shift lever- $40shipped -rear brakes $65shipped (needs pads and blockoff plate) -More rear brake parts 2 calipers and 2 plungers -Brand new crank rod w/ bearings $50.00 shipped -Kickass brand filters could be used for about anything $40.00 shipped - stock shift lever $20 shipped -Dogbone $10 shipped -Coil $25 shipped -Stock stator cover $10.00 shipped Also have a few internal motor parts kickstart gears, shift shafts if you need one hit me up and we can work out a price Pictures here: http://s1208.photobucket.com/albums/cc375/bansheeboy2004/
  6. I will take the seat send me pics of it and the basket to [email protected]
  7. How much for the seat? U have the billet basket still?
  8. Give u 200 shipped for ur lockout cover and velvet seat
  9. Polished?
  10. 15-15.5 Rear marvin shaw, aluminum drag tank, shear same side oof drags chrome, front spindles, 12 pdl extremes rears, polished lockout cover
  11. Good crank all bearings good and tight! $200 shipped Polished cases no chain breaks has hardware-$200 shipped Complete trans-$200 shipped (everything but the basket and pressure plate but has everything from the top to bottom) Shift shaft $15 shipped Kick gear $10 shipped Pic here: http://s1208.photobucket.com/albums/cc375/bansheeboy2004/Yo/
  12. Cases no breaks-180 Shipped -Kickstart gear 15 shipped - Basket w/bearing washers and nut-75 Shipped -Inner hub-20 shipped -pressure plate w/ bolts and springs-20 shipped -Good clutch-15 shipped -Clutch push rod-15 shipped -Rod & ball-10 shipped -Stock coil-35 shipped MISC... Dogbone w/ link 20 shipped - crank with seized rod bearing will come w/ new rod and bearings to make it good-100 shipped -crank with rod broken rod and 1 bad outer bearing(Flywheel side) comes with new rod and bearings-75 shipped(still will need outer bearing to make good) Clutch cover w/ impeller-35 shipped Kickstart-35 shipped pictures here copy and paste link http://s1208.photobucket.com/albums/cc375/bansheeboy2004/
  13. Very clean. Pads still look new. 110 shipped pics here http://s1208.photobucket.com/albums/cc375/bansheeboy2004/brakes/
  14. ALL TRANNY PARTS SOLD the tranny and complete tanny w/clutch components
  15. GOOD STOCK CRANK SOLD
  16. CYLINDERS AND STATOR SOLD
  17. i have a complete bottom end
  18. SWIGARM BOLT AND IGNITION SOLD
  19. 2 motors first one is a 1998 -Cases some of the best cleanest cases i've ever seen-200 shipped -Cylinders stock bore and no porting w/ stock head-250 shipped -Good crank w/ gears-200 shipped -Complete tranny w/ drum and forks w/ entire clutch components-250 shipped -Ignition flywheel,stator,and cdi-175 shipped -Kickstart gear 10 shipped The other motor is a 1996 -Cases typical top chain break and bottom end gouge from breaking rod but still good 60 shipped -Tranny w/drum and forks-125 shipped - Basket w/bearing washers and nut-80 shipped -Inner hub-20 shipped -pressure plate w/ bolts and springs-20 shipped -Good clutch-15 shipped -Clutch push rod-20 shipped -Rod & ball-10 shipped MISC... Dogbone w/ link 20 shipped - crank with seized rod bearing will come w/ new rod and bearings to make it good-125 shipped -crank with rod broken rod and 1 bad outer bearing(Flywheel side) comes with new rod and bearings-100 shipped (still will need outer bearing to make good) Clutch cover w/ impeller-35 shipped Swingarm bolt 15 shipped Kickstart-35 shipped Stator 60 shipped Most everything will come with necessary hardware. pictures here http://s1208.photobucket.com/albums/cc375/bansheeboy2004/
  20. your pm's are full do you still have your coil pm me if you do
