river runner
Everything posted by river runner
  1. Brother just put t5's on his new banshee and a milled head I gave him and the K & N seperate filters. I advised him to put 330 mains and 30 pilots but still falling off hard on the top end(white plugs )I guess the alt. around 1500ft. Anything for suggestions??? Thanks (130 compression stock reeds)
  2. Have you installed your shocks yet, to see the difference? Let us know what you think. Later
  3. Tusk still working great for me,about 2 months now. Got mine at ROCKY MOUNTAIN also.
  4. Does anyone have a picture of a rear YFZ450 shock installed on a banshee? and does it do anything to the ride hieght? Thanks
  5. Lookinf for a front pair of YZF450 shocks. Thanks, Chris Huie
  6. The bottom of the shock of yfz looks different! Are you sure it will work?
  7. Has anyone else put these on stock a-arms and found that these are a lot better than stock? Thinking about trying them seems how you can pick them up pretty resonable on e-bay. What about the rear shock does it fit and work good also? Thanks, Chris Huie
  8. Not a perfect fit but they work? Sounds bitchen
  9. Will these fit I like the sound of the silencers from toomey, but I love the low end and mid range power of the gnarly's. Thanks for the help.
  10. I just installed the tusk and left the cushions in and havn't had any problems. I figure they are there for a reason might as well use them. No strange noises coming from my bike. Later
  11. Works great so far yesterday was my first trip with it. I recommend it so far. Later
  12. Just took Shee out since finnally got the clutch adjusted right. What a difference over stock! apperently it must have slipped alot before but know it's sweet. The clutch pressure in your lever isn't to bad either. Deffinitly recommend for $43.00. The problem I was having with the adjustment was the after market clutch cable was a little too short and was screwing up the whole adjustment.
  13. I bought one deffinitley could tell throttle response diffrence. Have no problems with mine.
  14. Thanks Banshee Jerry appreciate the information.
  15. do you think I should remove the rubber cushions or not??????Thanks
  16. I just installed the cluth from Rocky Mountain Atv. for $43.00 But I left the rubber cushions in, should I have removed them? I ran it down the street and it works great but at a stop, it kind of wants to move forward even after trying to adjust the lever adjustment out. Of course making it difficult to get in nuetral if not almost impossible. Please advise on if maybe it just needs break in time or what. Thanks for the help, Chris Huie
