JERKHEAD
Everything posted by JERKHEAD
  1. alright guys... took the shee out for a run today and got her to idle - thanks to you guys... boy does shee pull hard and strong - what a freqin difference!!! new problem... when im on full throttle on sixth gear it pulls then tends to slow down then pick up again (like it hit its peak or something)... is this also a part of my jetting??? thanks guys for the help again...
  2. it idles fine when the choke is full but stahls when i close the choke... yes both carbs are sync perfectly... im gonna go a slot richer on the needle , to see if that wrks today...
  3. just installed a 28mm bored to 30mm - its already been pre jetted with a 155 main and the clip for the jet needle is on the 3rd slot ( i'm at sea level if it helps) and on top of the that i installed boyesen power reeds (which told me to go to the 4th slot to make it richer)... problems is - when i start the shee in full choke she she idles awsomely, but when i clsoe the chokes it dies... but it never dies when i give it a lil bit of throttle... what should i do? go richer on the needle one slot??? or.... thanks guys...
  4. need (thumb) throttle cable for a keihn pwk 30mm... does the stock throttle cable work? if not please let me know thanks 4 your help... * need part# or * where to get one
