ESR Temp Gauge
werner
I like the look of them, but I wanted to mount it on the plastic on the front fender next to the tank. The problem with that is I don't think it can be mounted because of the way it is designed. I think you just cut the water line and insert it and when you want the temp you need to bend down and look under the tank to see it. I wanted to see it when I ride, and haven't yet seen one that is made that you install like that. I have seen a lot that people have modified which is probably what I am going to have to do.............
