First plug chop. How's it look?
travisg77
Finally got around to doing a plug chop last weekend after a few modifications that I got from Jeff at FAST. Trying to get the jetting dialed in. What do you all think so far? Engine warmed up on old plugs. New plugs installed and ran WFO for one pass.
2006 SE
Temp: 90 degrees    Elevation: 1000' St Joe MO
Stock carbs
Pilot jet: 30   I might bump these down to a 27.5 to crisp up the bottom end a little
Main: 310
Needle: stock middle positon
A/S: 1.5 turns
Carbs synched with carb tool from Jeff
Klotz 32:1
50/50 race fuel/91 octane
Toomey 2-1 air fliter with outerwear
FAST billet adjustable timing +5
Noss/FAST head 21cc domes
Fatty pipes for now
Vforce4 reeds
Compression: 149/147
Stock jugs/bore with no porting
In-line temp gauge installed after the head: Runs betwwen 160-170 degrees
Serval 421 upcoming this winter
I missed the fact your running race fuel... at 150ish PSI and no porting and +4 timing you should be more then fine on pump.
If you have access to only shity gas stations id maybe run  a little race fuel but def not 50/50
I have a 250R that I mix 50/50 with. That's why I have been using it. Probably a little over kill for the Banshee with the current mods.
Would I be safe going down to 27.5 on the pilot with my current setup. When I adjust my air screws my idle keeps going up a little when I back them out. It idles higher at 2.5-3 turns out then it does at 2.-1 turn out.
I thought I read on here that if it does that then the pilot needs to go down one size until you get it around 1.5 on the air screw...
Thanks
