Im in the process of a rebuild but have forgotten how to mount the radiator. i got the two bolts on the sides screwed down, but i forgot how the third top bolt connects. i know it involved that big metal collar thing but i cant seem to figgure it out, or locate another post regaurding my question. can some one post me a picture? another question i have, where does the hose from my pro design cool heads go? is it just a breather? im talking about the hose on the top of the heads near the spark plugs. thanks
alright well all i realy need is a picture. ill greatly appreciate one
What is throwing you off is your probly missing the the bolt that holds the steering stem on.. you put a regular bolt on there insead of the one with the hole through the center!!!
ok look @ # 6 , 9 , 5 , 8 .
all of those numbers screw into the middle of the bolt. that holds the steering stem on . only one side of the stem has a special bolt.(with thread drill in center of it ) (make sure you have 6,9,5,8, because if you dont bolt
#6 will botom out and snap)
. hope this makes sense .
you have done it before you know what chinese shit i am talking about ..
i found it .... you need number 10 , your using two #9 and you dont know where to mount the radiator !
and the hose from the cool head goes back to the radiator. (not the overflow) there is a neck on the right side . look @ radiator its the same size as the overflow.
i feel stupid because i figgured it out before i read your post. & yes your explantion was good and makes perfect sence. i bought a that stainless steel bolt kit of ebay and the bolts are alan head bolts. i had remembered a funky looking bolt and when i gave digged it i discovered it was a specialty bolt with a threds taped inside the bolt itself. thanks for the help, i hope this will anyone else like me with the same problem.
