just ot done rebuilding my shee...added modquad head and boysen reeds...cant get it to run right...engine starts...when you rev it up it will stay reved and then slowly make it way down to an idle.....ive checked for leaks but still to no avail....any ideas?...
thank you
trevor
ps still running stock carbs
Sounds like a jetting and idle problem. When the idle is high, you give it gas, and it stays revved for a little bit before coming down.
Look there first, try adjusting as needed.
right tryin that now...running 240 jet bumpin up to 280...sees if she runs rich..then can back down with needle???
trevor
sounds to me like you either have a leaky intake gasket or the
springs inside your carbs are in a bind.
list all the mods done to your bike.
pos boost bottle
mod quad head with 21 cc dome
toomey t6 full exhaust
kn filter
wiseco stock pistons
removed tors
at a loss here...check for leaks..and there was none...just seems odd everything ran great up to the point of droppin a ring..no cylinder scores thank god....drop in the new mod quad head and domes and now it dont wanna idle. took everything back to stock as per the manual and still wont run right...thought i was on to something lastnight but i was wrong.....PLEASE HELP!!!
Trevor
pos boost bottle
kn filter
removed tors
Trevor
also i forgot to mention...running a 280 main...with the needle set at 2nd from the top...thanks again
trevor
