2004LEBanshee Posted July 20, 2008 Report Posted July 20, 2008 I have a clutch from jeff and I was wondering what spring bolts everyone is using. Also what kinda clutch boss. Reason I ask is I tried using stock bolts but I broke one or two trying to tighten them. So I bought matching bolts from the hardware store and got washers to go with. I used these for about 6 months and had to take the clutch apart due to a wreck. When I went to re-install the clutch I noticed that my washers had too big of a whole compared to the bolt and tore up the end of my clutch boss posts. I went to the store bought a new boss, longer bolts ( the short ones I thought were to short for those springs) , and new washers installed the clutch. I made two passed at the local dirt drags and one of my posts which the bolt goes through on the clutch boss riped completely off the boss. Quote
rubberneck Posted July 20, 2008 Report Posted July 20, 2008 I run the stock bolts. When you tightened them the first time did you use a torque wrench? I believe the manual says 7 ft-lbs if i remember correctly. If you use thread locker or lubricant on the bolts before you put them in, that is too much imho. I put blue loctite on them and only go to a couple of ft-lbs and leave them be, never had a problem. Quote
2004LEBanshee Posted July 20, 2008 Author Report Posted July 20, 2008 Yes. When I first put my motor together I tried to use the stock bolts with the new clutch. I dont think I even got to 7 (your right about seven) they just popped. ON or two out of the first 4 I just said f*ck it and bought different bolts. So your saying you use a stock inner hub or clutch boss and stock bolts. You blue locktight and use less then 7 LB's. Quote
rubberneck Posted July 20, 2008 Report Posted July 20, 2008 Yes. When I first put my motor together I tried to use the stock bolts with the new clutch. I dont think I even got to 7 (your right about seven) they just popped. ON or two out of the first 4 I just said f*ck it and bought different bolts. So your saying you use a stock inner hub or clutch boss and stock bolts. You blue locktight and use less then 7 LB's. Yep all stock stuff, blue or purple loctite, whichever is closer to me at the time LOl and torque to about 4 ftpds or so. I use an inch pound torque wrench set to 48-50 inch pounds. works good for me. Just a thought, but what brand torque wrench are you using. If it is a cheap one and it is in fact a ft/lb wrench, i wouldn't expect it to be very accurate down at the bottom of the scale which 7 pounds is going to be near the bottom of any ft/lb wrench. Thats why i use a 1/4" drive inch pounder Quote
2004LEBanshee Posted July 20, 2008 Author Report Posted July 20, 2008 Yea it was from sears. Probably not the most accurate. In fact I bought it when I build this engine last winter. It is foot pounds and it is at the bottom. Im going to have to try one like you mentioned. Quote
