Well, everyone, I just bought myself a rolling chassis and a motor from seperate sources and have put them together in hopes of building a decent sand bike. I am not new to modding and hot rodding, but this is my first two stroke and first quad in general. Here is what I have:
Stock motor, rebuilt with Wiseco pistons, .020 overbore
Hot Rods crankshaft, stock stroke
Stock head, not shaved or milled in any way
Mild dune port
FMF Fatty Gold Series pipes
FMF Turbine Core 2 silencers
Boyesen reeds
Stock timing settings
Stock carbs w/ TORS removed (using Vito's kit)
K&N pod filters w/ outers
Everything else on the engine which hasn't been listed is stock
What does everyone recommend as far as jetting is concerned? I bought a Vito's jetting kit and have installed the jet needles, but I am not sure what to use as a baseline for the main jet. I will be riding at Silver Lake in Michigan, which is around 700 ft. above sea level. Most all of my riding will be easily below 1000 ft.
Thanks guys!
Edited by ChippewaTSI94
Mild dune port
Boyesen reeds
Thanks guys!
i would start out with 320 mians 27.5 pilot and the needle in the 3rd clip from the blunt end.
i had a bike with very similar mods and i am in MI as well,that shoud be a good starting point for you.
once you get it running you may have to go up or down a size on the main,..just read your plugs
Dan
