hey, my banshee will run fine, as long as you don't turn the bars to the left. if you turn the bars all the way to the right, its fine. if you turn the bars all the way to the left it dies out. what's going on. it sounds electrical and that's not one of my strong points. does anyone know what it is or could be?
Sounds like you have a short in your multifunction switch harness or your key switch harness. Trace your wires and look for worn or bare spots, most suspect area is the keepers next to your steering stem mount. Have fun!
yeah, i just got done from tracing the wires from the main switch housing and sprayed clean the big white wire connection, that comes from the main switch housing and took off the safety wire thing for the parking brake. also, the ignition key switch doesn't work, cause the previous owner put a scotch lock in the wiring. i just got done trying it out and it seems to be working fine. thanks again.
