I was wondering if anybody has any gaskets for the stock head lying around, I could use a couple to put on both sides of my spacer plate so that I can make sure I'm getting a good seal. Let me know and we can work out a price from there, if you have one or two, either way.
i got one set for you. do you need 2? dont listen to 98_shee, he doen't know what he's talking about. :biggrin: jk
I have your address Jesse don't make me come up there!!!!! :tongue: :beer:
what setup are you running a plate on top of the motor usually only do that on 10mm.
if its a 4mm get stroker domes or put the plate under the jugs.
Two would be preferable, but if one's all you have I could probably get the other one from someone else.
Wes, Vito's actually makes this for 4mm stroker setups, and it is a head plate. Kevin hooked me up with it and said it should work fine for my setup since the head's shaved and the cylinders were decked. The domes are already cut, and I don't want to run it underneath the jugs because that would change my port timing.
